gamestoned
Oct 13, 2018Aspirant
XR500 lag on IPTV
Hello everyone,
I'm facing an add issue on my brand new XR500. Configured IPTV on my Samsung MU8000 using SmartIPTV app but while swiping channels it takes anywhere between 10-15 secs & most of...
gamestoned
Oct 14, 2018Aspirant
It was enabled and disabled. Both options didn't get any change in the result.
Gambito
Dec 11, 2018Aspirant
Hey bro did u resolve your issue already?
I have the same problem here with my Qled 6 tv. Can’t open the Chanel’s in my SMART IPTV.
- gamestonedDec 11, 2018Aspirant
Hey buddy,
The issue is still there & i have opened a formal suppot ticket with Netgear. They are investigating & I'm having calls with their L2 support. They are trying different settings & taking debug logs. I would suggest you do the same. Let's hope for the best.
PJ
- GambitoDec 11, 2018AspirantI already did that bro and nothing changes. Am done. The only way I can see my smart IPTV list is connecting my tv directly to my CM1000 modem. But that means that I let my other devices without internet. So I only do that at midnight
- Netduma-FraserDec 11, 2018NetDuma PartnerUsually IPTV does require a connection to the modem/ISP router. Is it possible to have the IPTV connected and the XR500 connected at the same time?
