Billybudz420
Dec 12, 2019Apprentice
xr500 laggy internet pauses
I've got terrible issues with wifi amd wored devices. I get horrible lag and brief pauses in my connection. Devices literally take min to load a page but speed test all are bout 17ms.....I'm on the la...
Billybudz420
Dec 16, 2019Apprentice
I have the xr500 connected to a Xfinity gateway which is in bridge mode.
Netduma-Fraser
Dec 17, 2019NetDuma Partner
Have you set any manual settings for the Xbox network settings at all? If so set them to Automatic. Seems strange its when this specific device is in use. Have you tried a factory reset and then after going through the setup wizard leaving everything on the default settings and seeing if it's still an issue?
