That_GamerYT's avatar
That_GamerYT
Apprentice
May 25, 2021
XR500 LAN IP DHCP glitching out
So occasionally (Usually 3-14 days uptime), the router stops assigning LAN IPs. Usually first, I can no longer access the DUMA OS interface from LAN. Then the internet stops working and I can't visit anything except 1.1.1.1 (Which happens to be my primary DNS server for the router in internet setup). Then the LAN IP of everything (WiFi and Ethernet) go away. However, I still have internet access from the router as I'm still able to remotely access the router with the "Remote Management" feature using my iPhone while connected to my cellular data (I always use a VPN during remote access to keep the login credentials and my WAN IP encrypted). So I think that proves that it's a LAN issue and not a WAN/ISP issue. The solution is usually to just change the routers LAN IP from 192.168.8.1 to 192.168.1.1 (Or any other number) and then change it back to 192.168.8.1 after that. However, while that lasted good for about a week, after that, almost half of the R-Apps were taking longer to load than expected. I clicked "Ok" on the notification and waited 30+ minutes while I was eating dinner and it was still loading when I came back so I had to reboot the router. Rebooting the router always fixes the problem, but it's not ideal to have to reboot the router that often. Today was a litle bit different. The router stopped assigning LAN IPs for like 5 minutes and then it would fix itself. Then 10 minutes later, it did it again and then fixed itself again. Once I got an IP, I logged in and tried going to Hybrid VPN and then it gave me a message saying "Uncaught SecurityError: Blocked a frame with origin "http://192.168.8.1" from accessing a cross-origin frame." and then I got completly locked out of the router (Meaning "192.168.8.1 took too long to respond"). I always access the interface from LAN on Ethernet so it's not a guest network issue. Here's my "LAN Setup" configuration:
Device name: XR500
IP Address: 192.168.8.1
IP Subnet Mask: 255.255.0.0
RIP Direction: Both
RIP Version: Disabled
Use Router as DHCP server: ✅
Starting IP address: 192.168.8.2
Ending IP address: 192.168.8.23
I have IP reservations all the way from 192.168.8.2-192.168.8.23 and it has all of my devices' MAC addresses and no I'm not using random hardware address/MAC spoofing on my devices so that's not the issue. IPV6 is also disabled.
Also, is this the issue I might be dealing with?
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/XR500-intermittent-network-issues/td-p/1940649
  • Sorry to hear this, thanks for including all these details though, that's very helpful!
    What firmware version are you currently running?
    The latest DumaOS 3.0 beta firmware currently has a fix implemented for an issue that sounds very similar to yours, so it could be worth you upgrading to this:
    https://www.dropbox.com/s/l3oeb6dw25ngmwm/XR500-V2.3.2.120.zip?dl=0
    I'd advise you factory reset after upgrading firmware as it clears out any low-level code left over from the previous firmware. Apologies for  any inconvenience caused, I understand this may be a bit of a hassle to set everything up again.
    • That_GamerYT's avatar
      That_GamerYT
      Apprentice
      I'm on V2.3.2.114 but how do I upgrade to the beta? I see 2 files. Which one is the beta?
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        Sorry I should've been clearer, download the .img file, it's ~37mb in size.
        Then do the following:
        1. Open up your web browser and go to http://www.routerlogin.net.
        2. Log into your XR500 using the admin username and password.
        3. Click Settings > Administration > Firmware Upgrade page.
        4. Click Browser and locate the firmware image file.
        5. Click Upload.
        6. Wait for the firmware upgrade to complete.
        I'd reccomend also factory resetting after the upgrade to ensure you're starting from a clean slate.
