PolikosFoinix
Jan 26, 2019Star
XR500 Lan Ports - Fatal Flaw
Ok. So I have been at this since I bought my first XR500 from Amazon on March 28, 2018. For the first few months everything was great, didn't even have to blink at the router much less reboot ...
sivola
Jul 31, 2019Tutor
i tried everything exepct a switch in between, but i must say this is super said to consider this even a solution... why should i buy another accessory after buying a 300$ router... and have more space taken by another device in my living room.
How come you guys consider this a solution? am i the only one thinking this is really bad customer service?
Jul 31, 2019Guru - Experienced User
EIther try a switch or return the router and find something else.
sivola wrote:i tried everything exepct a switch in between, but i must say this is super said to consider this even a solution... why should i buy another accessory after buying a 300$ router... and have more space taken by another device in my living room.
