Jagged_God
Aug 07, 2018Tutor
XR500 Lan Ports Issue
I have suddenly got an issue with the LAN ports on my xr500.
They were intermittent, while back now, but in last couple of days it seems they don't seem to be recognizing anything at all.
- Aug 08, 2018My first thought would be have you turned off DHCP without giving the LAN devices static IP addresses?
I'll also send you a PM with the firmware.
Netduma-Fraser
Aug 08, 2018NetDuma Partner
- Jagged_GodAug 08, 2018Tutor
Hi Fraser,
Just checked and the tick box beside use 'router as DHCP server' is ticked.
I will try the firmware you PM'd and let you know how it goes.
James
Hi Fraser,
Just to let you know the firmware you sent has sorted the issue. Though I did have to reset the unit again before it worked but who cares when it works....now to rebuild my allow/deny list 'sigh' lol
Thanks again for that, was pulling hair out, much appreciated.
James
