pedro802
Jul 17, 2019Aspirant
XR500 Lan ports problem
There is no problem with wifi, but sometimes I get disconnected when I connect ps4 with lan cable. and it will resume normal immediately. There is no problem when I try to connect internet without ...
- Jul 17, 2019
Have you tried installing this hotfix firmware for dropouts? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
Netduma_Alex
Jul 17, 2019NetDuma Partner
pedro802
my router's firmware version is v2.3.2.40
Is it different from what you offer?
- Netduma_AlexJul 17, 2019NetDuma Partner
The hotfix firmware I linked you to is based on the same version, BUT it has a small fix which stops dropouts. Apart from that fix, it is the same as the version you've got.
- pedro802Jul 19, 2019Aspiranti have found the situation that when i playing 11vs11 game, lan port disconnect will happen.
If there are fewer people connected, there will be no problem.- Netduma_AlexJul 22, 2019NetDuma Partner
That's weird. Do you get disconnected frequently when doing bandwidth intensive tasks like streaming 4K video or downloading game patches?
