helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Netduma_Jack
Sep 10, 2018NetDuma Partner
The latest firmware was only just released - could you please check which version of the firmware you're on? You should be able to get the latest version without us sending it via PM since it's now publicly available; you might just need to install it.
Woodiam
Oct 07, 2018Initiate
I just started having the same issue. My logs are filled with [DoS Attack: ACK Scan] alerts.
- Netduma_JackOct 08, 2018NetDuma Partner
The 'DoS Attack' in the logs is almost certainly unrelated. It's just general white noise from the Internet (if you Google it you will see plenty of threads on this forum confirming it).
What exactly has happened? Has an Ethernet port failed on you?
- WoodiamOct 08, 2018InitiateEverything connected to LAN gets dropped while the worless works fine.
I just updated to the new firmware. Ill see if that solves my issue.
