helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
sontu09
Oct 16, 2018Tutor
Bought the router two days back and having the same problem from last day. Can i also have the firmware please ???
- Netduma-FraserOct 16, 2018NetDuma PartnerThe firmware with the fix should be the latest firmware installed. What version are you on?
- sontu09Oct 16, 2018TutorI have the recent firmware installed on the router which is 2.3.2.32
- Seanabong2200Oct 16, 2018ApprenticeMine is still having the same problem as well. They recorded it and sent it to the engineers. To see if they can fix the problem. They need to come out with a new firmware for it. Also I’ve noticed it I have ipv6 turned on. My wireless Xbox one will work at first with ipv6 then out of the blue while gaming you get kicked from the party and lag for a second but then can not reconnect to the party. Until the console is reset. I went into the router settings and saw that after that happened the console said it was only connected to ipv4. This router has problems. Hopefully the next firmware will fix it.
