helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Netduma-Fraser
Oct 16, 2018NetDuma Partner
The firmware with the fix should be the latest firmware installed. What version are you on?
sontu09
Oct 16, 2018Tutor
I have the recent firmware installed on the router which is 2.3.2.32
