helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
MrEric
Oct 31, 2018Guide
well , no luck with the Alpha Xbox update, LAN is still dropping. Back to wifi again...
- Netduma-FraserOct 31, 2018NetDuma PartnerThats disappointing. Teams had a meeting today about the issue so will hopefully be a resolution.
- Seanabong2200Oct 31, 2018ApprenticeDid netduma set up the qos on this router or was it netgear? I know geo filtering is from netduma. But qos is on older netgear routers and it sucks. Just last night I was only getting half my speed. So I turned off qos and rebooted the router and now I’m getting what I paid for.
- Seanabong2200Oct 31, 2018ApprenticeI hope you guy do come up with one ASAP.
- Netduma-FraserOct 31, 2018NetDuma PartnerEverything but settings is Netduma. Probably High Priority traffic was detected so throttled the connection
