helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
MyWebs
Nov 19, 2018Aspirant
My issue seems similar but maybe slightly different. My PS4 Pro will randomly report that the "LAN cable has been disconnected" XR500. It never loses the connection for very long, most often just a split second. I have the most recent firmware V2.3.2.32 running. When this problem first started happening I bought a brand new Cat6 as I figured that was the problem.
The only support I have left at this time is hardware and these forums. I'm not paying to get support for a faulty product that should have worked right from day one. So hopefully I can find some help here, otherwise I'll have to return this modem which I really don't want to do.
Netduma_Jack
Nov 20, 2018NetDuma Partner
Hi - have you tried using a different Ethernet port on the router in case there is a faulty one?
Also, have you raised a ticket with NETGEAR's official support? If you raise a case there, they will be able to give you full support too.
