helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
garylewis8
Nov 25, 2018Tutor
Just got this router on 11/24 and am experiencing the periodic disconnect for wired ports. I'm running firmware version .32 (latest as of this post.)
My cable modem is a Netgear CM1000. Everything was working fine with an Asus router until I "upgraded" to this one yesterday.
I saw in another thread that there might be a beta fix for this issue? I'd be willing to give it a try.
Posting a section of my log. It has the DHCP events that were mentioned in other posts in case that's related.
[DumaOS] DHCP new event., Sunday, November 25, 2018 09:02:25
[DumaOS] DHCP lease change., Sunday, November 25, 2018 09:02:25
[DHCP IP: 192.168.50.5] to MAC address d4:c9:ef:03:90:30, Sunday, November 25, 2018 09:02:43
[DumaOS] DHCP new event., Sunday, November 25, 2018 09:02:43
[DumaOS] DHCP lease change., Sunday, November 25, 2018 09:02:43
[DoS Attack: ARP Attack] from source: 76.102.128.1, Sunday, November 25, 2018 09:19:13
[DHCP IP: 192.168.50.202] to MAC address c4:b3:01:9f:a2:12, Sunday, November 25, 2018 09:29:56
[DumaOS] DHCP new event., Sunday, November 25, 2018 09:29:56
[DumaOS] DHCP lease change., Sunday, November 25, 2018 09:29:56
[admin login] from source 192.168.50.3, Sunday, November 25, 2018 09:33:24
[DHCP IP: 192.168.50.11] to MAC address 1c:1b:0d:0b:62:a4, Sunday, November 25, 2018 09:35:06
[DumaOS] DHCP new event., Sunday, November 25, 2018 09:35:06
[DumaOS] DHCP new lease allocated., Sunday, November 25, 2018 09:35:06
[DHCP IP: 192.168.50.202] to MAC address c4:b3:01:9f:a2:12, Sunday, November 25, 2018 09:38:10
[DumaOS] DHCP new event., Sunday, November 25, 2018 09:38:10
[DumaOS] DHCP lease change., Sunday, November 25, 2018 09:38:10
benshane
Nov 25, 2018Aspirant
Mine is still holding strong after changing the power settings on my Xbox from Instant on to power saver. Not sure if that's what's causing your issue or not but I was experiencing the same problem. WiFi seem to work fine but I would lose LAN lines and have to restart the router.
