helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Seanabong2200
Dec 01, 2018Apprentice
Geo field is not working since I have applied this update that you pm me to my router. Nothing shows up anymore at all in the field.
Netduma-Fraser
Dec 02, 2018NetDuma Partner
Quit the game to dashboard, delete device from the Geo-Filter then add it back and set up the Geo-Filter how you want. Flush the cloud then wait 2 minutes and boot the game up again, do you see things appearing on the map then?
- Seanabong2200Dec 02, 2018ApprenticeNope still not showing anything at all in the field.
- Netduma-FraserDec 02, 2018NetDuma PartnerCan you zoom out of the map please, do you see anything at all outside the radius?
- Seanabong2200Dec 02, 2018ApprenticeThere wasn’t anything at all. I downloaded the one you sent me a month ago and now it is working. I attached a picture. Looks like it is the same one though that you just sent.
