helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Seanabong2200
Dec 06, 2018Apprentice
No its been on I won’t disable I just reset the router. I don’t like that my games don’t get updated while the console is off. I like to spend my time I can play Xbox playing the games without waiting on updates. Too bad this 300.00 router can’t work good enough so I don’t have to restart every other day. For the last 3 months. Since I’ve bought it. Netgear just sent me another new one last Friday. and they didn’t want me to reset my old one and I had to give him my router login so they can send the router to the engineers. But the one I got just last week is doing the same thing. Today was its first time. Dropping all the lan ports until I reset it. I even leave the Xbox one on. When it doesn’t have connection. And restart the router and after the router bolts up. Bam. I have internet again. And everything goes back to normal.
Netduma-Fraser
Dec 06, 2018NetDuma Partner
Its not necessarily down to the router thats why both teams are looking at it but understand your frustration, hopefully will be a resolution soon.
