helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Netduma-Fraser
Dec 15, 2018NetDuma Partner
Yes it was released a few days ago, has quite a few new features and fixes. They will post a change log when they put it on the knowledge base but for now it's only available by checking on the router itself.
Seanabong2200
Dec 15, 2018Apprentice
Okay. cool beans. Ill have to install it when i get home. I have my QOS turn off at the time cause it seems the router performs better for me with is off but i do still use the GEO-FILTER. after i install the new firmware ill turn QOS back on and give it another try. When QOS is on seems like it slows down my internet more than anything.
- Netduma-FraserDec 15, 2018NetDuma PartnerThat could only happen if you're throttling too much or if you've perhaps disabled share excess
- Seanabong2200Dec 15, 2018Apprentice
Netduma-Fraser wrote:
That could only happen if you're throttling too much or if you've perhaps disabled share excessHonestly. I'm not even sure where share axcess is. And when you say throttling what are you refrencing too?
- Netduma-FraserDec 15, 2018NetDuma PartnerShare excess is in Bandwidth Allocation options. Throttling I'm referring to having your Anti-Bufferbloat percentages too low meaning your speeds are heavily affected.
