helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Netduma_Jack
Dec 19, 2018NetDuma Partner
If you disable QoS do you then get full speeds (the option is in Anti-Bufferbloat's advanced options)? And are you doing this test wired?
Seanabong2200
Dec 19, 2018Apprentice
Yes doing all test wired. With qos off I get about 236 and still 18 upload. But straight from the modem I get 400 and 25 upload.
