helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Hate
Dec 21, 2018Apprentice
Seanabong2200,
I know exactly how you feel, I had to find a solution out on my own, please try this in order:
Download this: http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.32.zip [2.3.2.32]
Install it onto your router (Settings > Administration > Firmware Update)
Once it's complete, perform a factory reset (Settings > Administration > Backup Settings > Erase)
Download this: http://www.downloads.netgear.com/files/GDC/XR500/XR500-V2.3.2.40.zip [2.3.2.40]
Install it on the your router (Settings > Administration > Firmware Update)
Reboot one last time (Settings > Administration > Reboot)
Set up your router
These steps above fixed my issue with the router disconnecting EVERY 24 hours.
Netduma-Fraser
Dec 21, 2018NetDuma Partner
Sean did you read my previous message?
Hate, theres not much need to do a factory reset before an upgrade, you'd want to do it after but happy it resolved issues you were having.
