helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Seanabong2200
Jan 16, 2019Apprentice
are you guys still trying to find a fix for lan ports dropping with instant on being turned on for consoles? or is that just a thing in the past?
Mr_smile
Jan 16, 2019Aspirant
Hi. Im still trying to fix the problem that i lose connection on lan 1. Sometimes it comes back and working. For the moment its dead.
- FURRYe38Jan 16, 2019Guru - Experienced User
If you haven't yet, open a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
Ask about an RMA.
In mean time, if you need more ports, add on a external GB switch, i.e. NG GS305/308 series.Have you manually reloaded FW and then factory reset the router and setup from scratch?
What devices do you connect to LAN 1?
