helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Seanabong2200
Jan 16, 2019Apprentice
MR_smile that does sound like a hardware issue. I would call netgear customer support and if it still has warrenty they will send you a new one. Ive recieved three of these routers so far.. due to them thinking my issue to the lan ports all not working from instant on being turned on. which isnt the case it is something in the routers firmware causing my issue but seems they will never fix the problem.. in my case
