helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Ozzmanj1
Feb 04, 2019Aspirant
It is not the switch that is the issue. It is the lan port on the XR500. Nothing connects when hardwired in. Neither my laptop, xbox, ps3/4, etc. Wireless works no issues, but nothing works when hardwired in. This is whether it is directly connected to the lan ports on the router or through a switch. My old wireless router died yesterday, ASUS, and everything was fine. I am already on my second XR500 since mid yesterday. Unless there is a firmware issue, which I have tried multiple firmwares to no avail, I will be returning this router today.
mebaby333
Feb 04, 2019Tutor
Everyone,
Call in and ask for this version of code, and it DOES fix the LAN Port issues. V2.3.2.26... Not sure if they are going to fix in future releases but i can confirm this one does work.
Thanks,
Dave
- Ozzmanj1Feb 04, 2019Aspirant
I appreciate you providing the firmware version. Any chance you can PM me the link for this firmware? I have already been on the phone with NG twice since yesterday
- mebaby333Feb 04, 2019Tutor
I Do Not have the link for the firmware... I also signed a non-disclouser agreement so you will have to call in.. Sorry but at least this will fix the issue..
Called NG support, told this was a hardware issue and no software will fix this. I will be returning it to BB within the hour and going with a different brand. Extremely disappointed with NG and this product. Always had great hardware in the past, guess it is time for a different brand to move on to.
I had an RMA also, and it DID NOT fix the issue. Only the code i posted earlier fixed this issue.
Thanks,
Dave
- FURRYe38Feb 04, 2019Guru - Experienced User
I would try to open a support ticket to see if you can get the beta code:
https://www.netgear.com/mynetgear/registration/login.aspx
