helpmepls321
Jun 18, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
mebaby333
Feb 04, 2019Tutor
Everyone,
Call in and ask for this version of code, and it DOES fix the LAN Port issues. V2.3.2.26... Not sure if they are going to fix in future releases but i can confirm this one does work.
Thanks,
Dave
Ozzmanj1
Feb 04, 2019Aspirant
Called NG support, told this was a hardware issue and no software will fix this. I will be returning it to BB within the hour and going with a different brand. Extremely disappointed with NG and this product. Always had great hardware in the past, guess it is time for a different brand to move on to.
- mebaby333Feb 04, 2019Tutor
I had an RMA also, and it DID NOT fix the issue. Only the code i posted earlier fixed this issue.
Thanks,
Dave
- FURRYe38Feb 04, 2019Guru
I would try to open a support ticket to see if you can get the beta code:
https://www.netgear.com/mynetgear/registration/login.aspx
