helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Mar 07, 2019Guru - Experienced User
Instant ON is a MS issue, not NG.
- PieCaptainMar 07, 2019Guide
ah i was just replying with my firmware etc, didn't realise your reply was to someone else (i just read the email update and didn't actually check the thread!)
- Robbbert22Mar 07, 2019AspirantThis only effects the xr500, also my xbox is disconnected. Only thing connected is the computer.... still needs to be rebooted
- FURRYe38Mar 07, 2019Guru - Experienced User
Try the DCHP Ip address suggestion.
Robbbert22 wrote:
This only effects the xr500, also my xbox is disconnected. Only thing connected is the computer.... still needs to be rebooted- Robbbert22Mar 07, 2019AspirantMy dhcp is 192.168.1.100-254 i prefer that over factory (old linksys fan)
- Seanabong2200Mar 07, 2019Apprentice
No it is not a microsoft issue you are incorrect. no other router ive ever own has this problem.. and to prove its not a ms issue i reconnected my r7000 and i had instant on mode turned on and never had it disconnect 6 days of using it. reconnected my xr500 and it happened within 1 day the very next morning all lan ports shut off until i restarted the router. that is stupid you would say it a ms issue. plus your telling me netgear routers suck so bad that even if ms was the problem it would shut down all lan ports on the router. come on mcfly give more proof to that bs statement
- Netduma-FraserMar 07, 2019NetDuma PartnerOther routers do experience the issue, not all of course but someone linked to it in this topic or another on the same matter. That's why there are multiple teams working on it including the Xbox teams. I appreciate that it's frustrating but they're working hard to get it sorted.
This is taking extremly long to the point that it seems they are sdaying they are working on it but truely they are not
