helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Mar 07, 2019Guru - Experienced User
Instant ON is a MS issue, not NG.
Robbbert22
Mar 07, 2019Aspirant
This only effects the xr500, also my xbox is disconnected. Only thing connected is the computer.... still needs to be rebooted
- FURRYe38Mar 07, 2019Guru - Experienced User
Try the DCHP Ip address suggestion.
Robbbert22 wrote:
This only effects the xr500, also my xbox is disconnected. Only thing connected is the computer.... still needs to be rebooted- Robbbert22Mar 07, 2019AspirantMy dhcp is 192.168.1.100-254 i prefer that over factory (old linksys fan)
