helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Robbbert22
Mar 07, 2019Aspirant
This only effects the xr500, also my xbox is disconnected. Only thing connected is the computer.... still needs to be rebooted
Mar 07, 2019Guru - Experienced User
Try the DCHP Ip address suggestion.
- Robbbert22Mar 07, 2019AspirantMy dhcp is 192.168.1.100-254 i prefer that over factory (old linksys fan)
