helpmepls321
Jun 17, 2018Aspirant
xr500 LAN ports sometime will stop working
hi i need some help sometime my netgear nighthawk xr500 LAN ports stops working.wifi work fine not sure how to fix it. can anybody help me
- Jun 18, 2018I've sent you a PM with firmware that may resolve the issue.
Bojangles239
Mar 14, 2019Aspirant
I’m too having this same issue with my router.
Thanks
Thanks
Mar 15, 2019Guru - Experienced User
What FW is currently loaded?
Have you tried a manual FW update to v32 or v2.1.0.6 using IE11 or FF to load the FW file, the do a factory reset and setup from scratch afterwards to see if the problem continues?
Thanks
- Bojangles239Mar 15, 2019AspirantFW 2.3.2.40
ISP Modem is Arris TG1682g- FURRYe38Mar 15, 2019Guru - Experienced User
Your ISP modem is a router as well. What mode is it working in? Router or Bridged?
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Bojangles239 wrote:
FW 2.3.2.40
ISP Modem is Arris TG1682g- Bojangles239Mar 15, 2019AspirantI have my ISP modem in bridge mode. It seems that every time I turn my Xbox off and then back on it has no connection. It connects fine through WiFi it’s just the lan port.
