Villageidiot14
Jul 27, 2022Follower
XR500 LAN ports sometimes will stop working
Had my router since October 2021. Been having this issue on and off. 3zcept it is for everything. TV connection, phones everything. I reset right down to the coax cable too and sometimes it works som...
Netduma-Fraser
Jul 27, 2022NetDuma Partner
Villageidiot14 In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
