huntj06
Jan 14, 2019Aspirant
XR500 Lan Ports stop working
I've had my router since early October and just a couple of days ago I've noticed when I go to get on my desktop PC I have no internet connectivity. My WiFi is working fine, but it seems the LAN port...
Jan 15, 2019Guru - Experienced User
Whats connected to the LAN ports on the router?
Whats the Mfr and model # of the ISP Modem the NG router is connected too?
Whats the Mfr and model # of the network adapter card connected to the router?
Swap LAN cables between the router and PC?
Try Different LAN ports on the router.
Try a Different LAN PC to see if problem is seen with another PC.
Factory reset the router and setup from scratch.
- huntj06Jan 15, 2019Aspirant
I woke up this morning with my Hue bridge not responding as well. I've tried a new Ethernet cable along with swapping the cable to a different lan port.
I've not tried a factory reset yet, but that's my last resort. I see a lot of people having this issue. What's Netgear doing to fix it?
My Modem is a Arris SB8200 (less than a year old).
The Desktop that is having issues is a ASRock Z370 Motherboard with the built in ethernet card.. Not sure its the PC as the Hue bridge has issues as well (along with many other people on this forum).
