Drewidthegreat
Apr 05, 2019Tutor
XR500 LAN Problems
I have just changed from a D6200 to an XR500. The wireless side of everything works fine but I have no Ethernet connections. I have a cable that goes to my TV and one that goes to a CCTV box, one has ...
Apr 05, 2019Guru - Experienced User
Drewidthegreat
Apr 07, 2019Tutor
I have the latest firmware installed as i updated the router when i installed it but i dont know the actual version. The modem is the standard BT Openreach fibre router that they supply with the connection. I cant get the actual details at the moment as i am away but will get them if this helps.
As i say, the wireless is fine and i can connect to the internet through a wireless connection its just the LAN connections that dont work
Thanks very much
