Drewidthegreat
Apr 05, 2019Tutor
XR500 LAN Problems
I have just changed from a D6200 to an XR500. The wireless side of everything works fine but I have no Ethernet connections. I have a cable that goes to my TV and one that goes to a CCTV box, one has ...
Netduma-Fraser
Apr 06, 2019NetDuma Partner
You mentioned you're using BT, have you put the PPPoE details in the XR500?
Drewidthegreat
Apr 07, 2019Tutor
Sorry for sounding a bit vague but by PPPoE do you mean the email that i was asked for, if so i put in btbroadband@btbroadband.com with a password of bt is this what you mean.
Sorry but as you can tell my techinial knowledge of internet etc is pretty limited
Thanks
- Netduma-FraserApr 07, 2019NetDuma PartnerYes that's what I mean. There is a setting in WAN related to BT I believe, enable it and see if that helps please.
- DrewidthegreatApr 07, 2019Tutor
OK, thanks very much, when i get back i will log into the router again and take a look at the settings for the BT settings
I will let you know how i get on
Thanks
