Drewidthegreat
Apr 05, 2019Tutor
XR500 LAN Problems
I have just changed from a D6200 to an XR500. The wireless side of everything works fine but I have no Ethernet connections. I have a cable that goes to my TV and one that goes to a CCTV box, one has ...
Apr 07, 2019Guru - Experienced User
Modem Router Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Drewidthegreat wrote:
I have just changed from a D6200 to an XR500. The wireless side of everything works fine but I have no Ethernet connections. I have a cable that goes to my TV and one that goes to a CCTV box, one has an orange light (cctv) and one has a white light (tv) but I have no internet connection on either of them. The D6200 connects perfectly. I am running on BT openreach fibre if that makes any difference. I can’t seem to find anything relating to this, is it a faulty router. I have upgraded the firmware etc, re-booted everything in the correct order so am back using the D6200 until it’s sorted, any help would be appreciated
