AMUMU
Aug 19, 2019Aspirant
XR500 League of Legends game voice chat disconnect
Hi, anyone can help me fix the League of Legends game voice chat disconnect problem? i had already disable the WAN steup: SIP ALG. but it doesn't work. I don't know what happened.
Netduma_Alex
Aug 20, 2019NetDuma Partner
Are you using Geo-Filter?
AMUMU
Aug 20, 2019Aspirant
I don’t know where is Geo filter? Could you tell me more about this ? Thanks for your help
- lorein0688Aug 20, 2019Aspirant
Well, this might be a tft related bug and installing the next patch fix the issue or else start using discord, this worked for many gamers playing the league of legends game.
- AMUMUAug 21, 2019AspirantOh, I see, but my league of legends voice chat could not connect, it is disconnect. I couldn’t speak with my friends during the game.
- Netduma_AlexAug 22, 2019NetDuma Partner
You can disable QoS in the side menu next to Anti-Bufferbloat
- Netduma_AlexAug 21, 2019NetDuma Partner
I was just checking wether you were using Geo-Filter and that was blocking the connection. Sounds like you're not.
- Netduma-FraserAug 21, 2019NetDuma PartnerDisable QoS completely from the Anti-Bufferbloat option menu on the QoS page, does that resolve the issue?
- AMUMUAug 21, 2019AspirantI used never. But it doesn’t work. Is that 5060 SIP problem?
- AMUMUAug 21, 2019AspirantI used it. Omg . So should I disable ?
