Aug 16, 2019Guru - Experienced User
New - XR450/XR500 v2.3.2.56 Firmware Update Available...
New Features and Enhancements: Support France Free and Orange ISP of the IPTV configuration. Support GUI login weak password protection. Bug Fixes: Fixes security vulnerability issues. Fixes t...
- Aug 17, 2019
Replied back here:
Jl92 wrote:
I have posted my issue in the XR500 forum. This is just a note to mention that with the v56 FW, my internet access ceased on 8/16. I had auto update set on my router. Setup with 5268 AT&T modem was working great for past two months. Not sure if my issue is coincidence but it seems suspicious to come right when the new FW came out. Ive gone through all trouble shooting in manual, factory resets, reboots. Being helped by someone in the other forum but so far no luck.
Aug 22, 2019Guru - Experienced User
You'll need to respond there and keep in touch with them there.
Good Luck.
jordi08110 wrote:
Ticket opened in july.....
Netduma-Fraser
Aug 22, 2019NetDuma Partner
I've let our team know as well about this so they can communicate with Netgear about who needs to improve the synergy between app and DumaOS.
- FURRYe38Aug 22, 2019Guru - Experienced User
Thank you Sir. :smileywink:
