Smiley3303
Dec 15, 2019Star
XR500 Lease Time Issues
I am still having issues the lease time ending and causing loss of internet for at least a minute. Is there plans to update the firmware so I can control the time of this issue and the duration? ...
Joshwilmott11
Mar 01, 2020Aspirant
Wondering if you have found a fix for this, having similar issues with my D7000 but my lease time is set to 1 hour....doesn’t release and renew automatically so disconnects all devices for a minute or more, unless I watch it like a hawk and renew manually
Netduma-Fraser
Mar 02, 2020NetDuma Partner
Joshwilmott11 I would suggest you post here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk as that may be a different issue and it also uses different software to the XR range.
