CMXR5001K
Dec 28, 2020Aspirant
XR500 Limiting 100MB to Ethernet Ports
Hello, For some reason, my XR500 is limiting my download speeds to 100mb on my ethernet ports, and my wifi. It was not doing this a few days ago, this just started out of no where. I have...
CMXR5001K
No, changing the cables does nothing. I’ve tried multiple, brand new cat 7 cables.
This is also a new issue, it was fine a few days ago, nothing has changed.
CMXR5001K
It's also not just the ethernet, it's limiting the WIFI as well to 100mb
- Netduma-FraserDec 29, 2020NetDuma PartnerDid you replace the ethernet connecting the router to the modem? As that is the one that would also have an affect on the wireless speeds.
- CMXR5001KDec 29, 2020Aspirant
Yes.
- plemansDec 29, 2020Guru - Experienced User
Have you tried going in manually to set the qos for gigabit speeds?
A tried a simple factory reset on the router?
what firmware is currently on the router?
I've tried changing it manually to 1000/1000 Yes, nothing changed, and I've disabled it all together, nothing has changed.
I've factory reset the router twice so far, no changes.
It's currently on V2.3.2.66
- Netduma-FraserDec 29, 2020NetDuma PartnerDo a factory reset and setup from scratch and see if it works properly then.
