Cheetoz
Nov 28, 2019Tutor
xr500 limiting my internet with QOS disabled.
Hello all, I have read some of the articles on the forums but none seems to have the same situation as I am, I have a 400mbps internet speed but I don't get that speed whenever I am connected to...
Netduma-Fraser
Nov 29, 2019NetDuma Partner
How have you disabled the QoS? You should disable it from the Anti-Bufferbloat 3 line menu. Also how are you doing the Speedtest, via Ethernet?
Cheetoz
Nov 29, 2019Tutor
Through Anti-bufferbloat as you stated, I just bought another Modem that actually spectrum supports, I took the risk activating the SB8200 it worked for a few days but I believe there is some glitch going on with it since the modem is not under their supported modems yet, so now I bought the Netgear CM1000v2 and I am back at 400mbps even with QOS activated.
Thank you for your reply!
- Netduma-FraserNov 29, 2019NetDuma PartnerGreat to hear that, thanks for the update!
