bsilverthorn
Aug 12, 2018Apprentice
XR500 Locks up after latest firmware
After allowing the device to autoupdate, I have to reboot this new router every day. It just locks up, or drops the internet.
Reverted back a build and so far no issues.
Anyone have insight o...
bsilverthorn
2.3.2.22 seems like its got some issues, and no I don't have an XBOX one connected. I do have a 360 connected to it, but no one has used it since I installed the router, don't think its even been turned on. We mostly PC based gamers and Ipad.
When it drops internet, it appears Wifi gets a little hinky as well.
Netduma-Fraser
Aug 12, 2018NetDuma Partner
I've sent you a PM with firmware. Also provide a screenshot of the QoS settings you're using please
- bsilverthornAug 12, 2018Apprentice
Will do, I j ust reset it back to factory again. I will apply this after lunch EST and then set it backup and send you what I have set.
Thank you, man I hope this helps. I expected this thing to kick my other nighthawks butt ;-).
Man this board software is lame the way it handles pics.
I will post them again.
For some reason I could put in text at the start or the end.
MAX BW is 175 meg on a good day down
Up its 25
The average is right about where it is set.
