P111
Nov 06, 2018Luminary
XR500 Lockup. ( disconnect? )
OK for the first time the router died. It's been running continuously for maybe a week. I came to it in the morning and it was dead. Funny thing is that the wireless was even switched off. It was onl...
Nov 06, 2018Guru - Experienced User
Haven't seen this issue nor with others i know who have this router.
Whats the router connected too? Both ISP modem and devices?
Any LAN switches in the mix?
Have you tried loading the first FW version for the 500 manually, then factory reset then setup from scratch and see if the problem happens again?
