zane_samples
Mar 30, 2020Aspirant
XR500 loses connection to xbox one x briefly
I have a Xbox one x that is hard wired into the router, the past couple of days when I play xbox every other hour I get a notification that connection is lost and I see the light for my LAN device t...
zane_samples
- Netduma-FraserMar 31, 2020NetDuma PartnerCould you double check to see if you connect it via WiFi if you get the same issue or if it works without disconnecting please?
- zane_samplesMar 31, 2020Aspirant
It only disconnects randomly when its wired but I experiance really slow speeds on both wired and wireless.
- Netduma-FraserMar 31, 2020NetDuma PartnerLets try to resolve the disconnection issue first, could you give the Xbox a static/reserved IP in LAN Settings please and see if that resolves the issue.
