zane_samples
Mar 30, 2020Aspirant
XR500 loses connection to xbox one x briefly
I have a Xbox one x that is hard wired into the router, the past couple of days when I play xbox every other hour I get a notification that connection is lost and I see the light for my LAN device t...
zane_samples
Netduma-Fraser
Mar 31, 2020NetDuma Partner
Could you double check to see if you connect it via WiFi if you get the same issue or if it works without disconnecting please?
- zane_samplesMar 31, 2020Aspirant
It only disconnects randomly when its wired but I experiance really slow speeds on both wired and wireless.
- Netduma-FraserMar 31, 2020NetDuma PartnerLets try to resolve the disconnection issue first, could you give the Xbox a static/reserved IP in LAN Settings please and see if that resolves the issue.
I did the ip address reservation for the xbox and have not had any dissconects today so I think that problem is resolved thank you. Earlier today I was downloading things and my xbox one x was the only device connected to the router but I would get around a 3 mbps and sometimes low kbps, those speeds were weirdly low since i have a 300 mbps plan from my isp. Thank you again for your help i have been looking for a solution for a long time to get stable speeds.
