SBum58
Nov 14, 2020Tutor
Xr500 losing LAN connection for a few seconds
So since the .56 FW update, and yes even after a reset clicking the tiny button in the back, my LAN connections just drop on me. It’s been happening to my Xbox, at first the X1X and now it’s happened ...
Netduma-Fraser
Nov 14, 2020NetDuma Partner
How often is it happening exactly? Is the XR connected to a pure modem (no WiFi) or a modem/router? You can try that yes just to check, you can find all the firmware versions here: https://www.netgear.com/support/product/XR500.aspx#download
SBum58
Nov 14, 2020Tutor
Well while playing Xbox I’d say once every few hours.. but I’ve been connected to my laptop now for the since I posted this and it’s dropped 3-4 times. Even did it while I was trying to upload the .40 FW.. As for the modem from spectrum is a non-wifi version I believe as it’s never provided wifi, but it does have the phone line jacks as it’s the only unit they carry in my area that can do the gig speeds. I’ve just reverted my FW to the .40 and hope that fixes the issue as I swear it never did this before the last update..
Edit: the exact modem is E31U2V1. Also wifi works great never see a hiccup like I am with the LAN connections.
- Netduma-FraserNov 15, 2020NetDuma PartnerThank you for the information, since reverting the firmware have you seen the issue again?
- SBum58Nov 15, 2020TutorNo full disconnects I think but I was experiencing lag/packet loss while playing rocket league. But that’s been happening for a while since Epic took over the game. I’m going to give this a week and will report back here if it continues to happen.
