IBTwist's avatar
IBTwist
XR500 Major Issues
Hello
I started having some major issues with my connectivity and settings in my Nighthawk XR500 router all of the sudden last night. For starters, connection became incredibly bad when it previously was great, and then I went and check in the Duma OS and my Device Manager was not working properly. Devices are showing as offline even though they are connected.
Using ATT, BGW210 modem to router setup
  • Also forgot to mention that the Geo Filter does not work for my xbox or any device. Nothing happens on that screen when I queue up for a game
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Reboot the router, do the devices appear online correctly then? Remove the Device from the Geo-Filter. Hard turn off the console, flush the cloud in the Geo-Filter map options. Re-add the device, wait 1-2 minutes and then turn on the Xbox again.
