mahobbs
Feb 06, 2021Aspirant
XR500 Media server bug v2.3.2.66
Hi Is anyone else having problems with media server functionality on the xr500 running the latest .66 release. I had no problems with it under the previous release but it just does not work reliab...
Xpunker1
Feb 06, 2021Initiate
I am having the same trouble. Server is visible but when trying to read or play a file just keeps loading with no successes. Only started happening after latest patch
Xpunker1
My firmware version is v2. 3.2.114 and Im have the same media server issues
- mahobbsFeb 07, 2021Aspirant
Thanks guys, good to know that I'm not the only one. My failure mode is exactly as described above, serving files behalves eratically and if a track does appear available it will time out if you try to play it.
Also useful to know .114 also has this issue, I won't bother spending many hours trying it.
I'll keep pushing the support case and update re .114.
- Netduma-FraserFeb 07, 2021NetDuma PartnerTry upgrading to the .114 DumaOS 3.0 beta version instead and see if it works on that please. Do a factory reset once upgraded https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-108-XR500/m-p/2047885/highlight/true#M3538
