mahobbs
Feb 06, 2021Aspirant
XR500 Media server bug v2.3.2.66
Hi Is anyone else having problems with media server functionality on the xr500 running the latest .66 release. I had no problems with it under the previous release but it just does not work reliab...
Xpunker1
Feb 06, 2021Initiate
My firmware version is v2. 3.2.114 and Im have the same media server issues
mahobbs
Feb 07, 2021Aspirant
Thanks guys, good to know that I'm not the only one. My failure mode is exactly as described above, serving files behalves eratically and if a track does appear available it will time out if you try to play it.
Also useful to know .114 also has this issue, I won't bother spending many hours trying it.
I'll keep pushing the support case and update re .114.
- Netduma-FraserFeb 07, 2021NetDuma PartnerTry upgrading to the .114 DumaOS 3.0 beta version instead and see if it works on that please. Do a factory reset once upgraded https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-108-XR500/m-p/2047885/highlight/true#M3538
