larsevss
Dec 14, 2018Aspirant
XR500 missing Hybrid VPN with latest firmware
I have XR500 and I do not see Hybrid VPN on the sidebar. You can see it from the attached screenshot.
I have updated to the latest firmware 2.3.2.40. I don't see the Hybrid VPN in any of the pr...
EnVy_Hype
Jan 10, 2019Aspirant
I just contacted netgear support and they said China prohibits the use of vpn-related services. I am really annoyed. It is really annoying that they don't tell you before hand.
maynardsdick
Jan 11, 2019Aspirant
This is so infuriating. The fact that Netgear gave in to the no VPN policies, and the lack of information regarding the missing features. I'm going to contact Netgear China and try to convince them to take back my router. Otherwise I hope this isn't hardware related and can be fixed.
- FURRYe38Jan 11, 2019Guru - Experienced User
You'll have take that up with the China gov't. NG has to play by there rules since China seems to prohibit various networking features in that country. VPN is allowed in most other countries. China seems to not want users having privacy.
- Netduma-FraserJan 11, 2019NetDuma PartnerAs above! However, I was pretty sure that Funjsq had the go ahead on the router. The feature when you change to your Native language it's doesn't work? The screenshot in the other topic looks like it's available.
- maynardsdickJan 11, 2019Aspirant
Funsjq is there when the client is switched to Chinese. But it's a so-called "gaming accelerator", which acts as a tunnelling device only for games, but not for anything else. The functionality of a VPN is basically none existent.
I understand the regulations and such the Chinese Government imposes on companies due to censorship, but it would be great if someone can provide some insight (probably anonymously) on whether these limitations can be bypassed. From the looks of it, the lack of Hybrid VPN should only be limited by software right?
Yeah the situation regarding these subjects is looking quite bleak. Things only seem to be getting worse.
- EnVy_HypeJan 12, 2019Aspirant
Netgear China now says that every single router in China is not supported. I have so many vpn routers and they still work in my parents home.
