Subbububbu
Sep 14, 2018Guide
XR500 MTU Values - PS4
Hi!
I was wondering whether the MTU values of my PS4 needs to be synchronised with that of my XR500's default values?
I play a lot of FPS and a lower than default MTU setting through my PS4 has usually helped with hit detection (albeit at the cost of losing frames every now and then).
Suggestions / advice?
- Leave the PS4 on automatic network settings, it will get the MTU from the router itself. Sorry to say MTU won't affect your hit detection so it's likely a placebo but if you're getting good games then thats the main thing!
1 Reply
- Netduma-FraserNetDuma PartnerLeave the PS4 on automatic network settings, it will get the MTU from the router itself. Sorry to say MTU won't affect your hit detection so it's likely a placebo but if you're getting good games then thats the main thing!
