droesw
Jun 06, 2019Guide
XR500 NAT, QoS, IPv6, and Latency Issues
So I've been having issues with my xr500. This is the second xr500 I've had and I'm currently on the latest firmware. I returned the first for a different reason, but the first major concern with thi...
droesw
Jun 07, 2019Guide
Rest of QoS settings
Netduma-Fraser
Jun 07, 2019NetDuma Partner
Thanks for that, just to clarify, when you've finished gaming etc and you're checking whether the speeds have gone back up or not, how are you testing this? Is it using the console settings or speedtest.net on a wired PC for example?
- droeswJun 10, 2019Guide
I've done the tests with speedtest.net on both ethernet and wifi on a computer, as well as xbox wired when I have qos on never
- Netduma_AlexJun 11, 2019NetDuma Partner
Try turning off IPv6, it's been known to cause issues with the QoS. The fact you say that it's sped up your connection previously suprises me i'll be honest.
