Gianpierre1111's avatar
Dec 18, 2022
xr500 need help with ap mode
i accidently turn ap mode on and cant switch it off because I cant connect to duma anymore so i cant turn it off any help would be appreciated pls
  • FURRYe38's avatar
    Find the IP address it gets from the host router it's connected to and connect there or do a factory reset on the XR and setup from scratch.
  • I think when in AP mode it changes the IP to access to 10.0.0.1 so try that then you should be able to switch back
