Ra7cio
Feb 17, 2021Aspirant
[XR500 Netduma] problem with dhcp Ubiquiti LocoM2
After yesterday update firmware to XR500 V2.3.2.114-DumaOS3.0.203 i have a huge problem. On list devices i cant see my Ubiquiti Loco M2 Access Point and Station. (bridge to other building). But fu...
Ra7cio
unfortunately Its connection problem, devices on another building have not connection to internet
Ra7cio
I try reconnect Loco M2.
Loco M2 station: 192.168.0.19
Loco M2 ap: 192.168.0.20
When i on lan cable work ok.
When i switch lan cable to xr500 one of Loco M2 (station) in second (ap) have info about LAST IP ADRESS (station): unknown.
- Ra7cioFeb 18, 2021AspirantSorry, cant edit. Some changes.
Loco M2 works fine, but have not access to internet. Have ip adress static, links Booth ok. But devices connect to Loco M2 dont get IP adress, dhcp for them not work.- Netduma-LiamFeb 18, 2021NetDuma Partner
OK so are you able to see devices in device manager when they connect to the AP? Are the devices able to ping the XR gateway address?
