crmontoy1
Mar 08, 2022Apprentice
xr500 netgear QoS traffic prioritization
i got a question!! i want to know what happen if i check this box....(apply to WAN)??? what is the funtionality of this? i play PS5
- Mar 10, 2022
The way it's currently configured is fine, assuming you're not having any NAT issues etc.
Netduma-Liam
Mar 09, 2022NetDuma Partner
Apply to WAN appends the same priority tags to your game traffic as it leaves the WAN interface. It's hard to know whether it will prioritised by the upstream router/ISP equipment, but there's no harm in doing it.
- crmontoy1Mar 09, 2022ApprenticeThks for your answer but what can u suggest me? Check the box or not? Im curious with that box i dont know the funcionality if will be helpful or not?
- Netduma-FraserMar 09, 2022NetDuma PartnerWe recommend enabling it, if it works you'll see a benefit, if it doesn't it won't cause any negative affects.
thks u so much i appreciate it !!!! now i got other doubt i need to know which box i need to check right here.... i want the best advice that you can give me i play FIFA in Ps5 i have many year trying to setup the router ,,,,, cause fifa is a real pain the axx with the connection ....
