crmontoy1
Mar 08, 2022Apprentice
xr500 netgear QoS traffic prioritization
i got a question!! i want to know what happen if i check this box....(apply to WAN)??? what is the funtionality of this? i play PS5
- Mar 10, 2022
The way it's currently configured is fine, assuming you're not having any NAT issues etc.
crmontoy1
Mar 09, 2022Apprentice
Thks for your answer but what can u suggest me? Check the box or not? Im curious with that box i dont know the funcionality if will be helpful or not?
Netduma-Fraser
Mar 09, 2022NetDuma Partner
We recommend enabling it, if it works you'll see a benefit, if it doesn't it won't cause any negative affects.
- crmontoy1Mar 09, 2022Apprentice
thks u so much i appreciate it !!!! now i got other doubt i need to know which box i need to check right here.... i want the best advice that you can give me i play FIFA in Ps5 i have many year trying to setup the router ,,,,, cause fifa is a real pain the axx with the connection ....
- Netduma-LiamMar 10, 2022NetDuma Partner
